Date/Time: Tue, 24 Dec 2024 02:09:54 +0000
candlestick customization- how to increase wick width
View Count: 3082
[2015-10-28 21:51:53] |
Joe Hobart - Posts: 89 |
I wanted to fatten up the wicks on my candles. The color setting works, but the width setting does not appear to be working with the wicks, only the body outline.
[2015-10-28 22:17:07] |
tobi - Posts: 351 |
You have to change the width of "Bar High-Low Down" and "Bar High-Low Up" for the wicks.
[2015-10-28 22:19:10] |
thanks tobi, that works!
[2015-10-29 05:42:12] |
This support request is considered answered and resolved.
