Date/Time: Tue, 24 Dec 2024 01:34:05 +0000
Arrange minimized windows
View Count: 1145
[2015-10-28 16:11:49] |
vrunrun - Posts: 53 |
Hi, For the "Arrange minimized windows" under the Window menu, I found that I've to re-use the command every time I log in SC in order to find the minimized charts within the chart book. Is there a way to "remember" the positions of the minimized windows so that I don't have to use the command every time I log in SC? I understand that double clicking chart tab can open the minimized chart but using this method, the chart is maximized and I can't see other charts in the chart book at the same time. By restoring minimized windows, I can open the desired chart with specifc size and specific location in my chart book. |
[2015-10-28 18:00:41] |
We have verified that the minimized position of chart windows is saved. If it is not saving on your system, refer to this help topic about this: Window Size and Position Not Restored When Opening Chartbook You can also right-click on a chart tab and select Restore to restore the window and not maximize it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
