Date/Time: Tue, 24 Dec 2024 01:58:48 +0000
Make copied drawings permanent on destination chart
View Count: 786
[2015-10-28 15:34:15] |
User529296 - Posts: 27 |
Hi SC, Sorry if I missed this on the manual. I was able to copy drawings from one chart to another in "Advanced Setting 2" under "Chart Settings". But the source chart needs to be opened at the same time to view the drawings on the destination chart. Is there a way to make these drawings permanent on the destination chart without having the source chart open? Thank you! TWA |
[2015-10-28 17:55:59] |
No. Definitely not.
