Date/Time: Sun, 08 Sep 2024 00:34:30 +0000
TransActBridge on linux/wine
View Count: 776
[2015-10-26 19:30:42] |
cross - Posts: 70 |
Hello, Has the TransActBridge program ever known to run under linux and wine? SC runs perfectly but the bridge seems to have some issue with the https connections (a small log attached). I don't wanna waste your time if the bridge is not in your scope. I just saw that it was updated in 1309, tho neither version works. Thanks |
Private File |
[2015-10-26 20:05:46] |
We would not recommend using the TransAct bridge program on WINE.
