Date/Time: Sun, 08 Sep 2024 00:29:37 +0000
Whats new in the latest versions
View Count: 1230
[2015-10-26 12:46:13] |
User98049 - Posts: 13 |
Hi Support, I was programming my code 8 months ago. Everything worked fine. Now, i returned into coding, and it seems that few of the functions are not exists anymore. The functions are: DeleteLineOrText(), and GetChartDrawing() HELP.... Ariel |
[2015-10-26 17:14:37] |
Check here for the new function names: https://www.sierrachart.com/index.php?page=doc/doc_ACSILDrawingTools.html These have been renamed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
