Date/Time: Fri, 18 Oct 2024 04:08:41 +0000
Dax
View Count: 857
[2015-10-26 09:21:02] |
User33440 - Posts: 1 |
Hi is from today that my dax chart don't update any more all other charts do it what could have appened?
[2015-10-26 09:51:25] |
Follow the instructions here to update the symbol settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps Use this new symbol format you will find in File >> Find Symbol >> Futures: DAX-######-DTB-EUR-25 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-26 09:51:58
