Date/Time: Wed, 25 Dec 2024 02:35:08 +0000
Trade and Current Quote Symbol issue?
View Count: 999
[2015-10-26 02:04:32]
User742717 Mike - Posts: 86
Hi SC.
I would assume, this feature is for micro/correlated markets.
GC-201512-CME and MGC-201512-CME works fine, so I'm not sure if this is an error or if it's correct.
Symbol: 6E-201512-CME
Trade and Current Quote Symbol: M6E-201512-CME
AMP-TT Sim1
Version: 1313, upgraded to 1316 and it's the same.
Market Sell, ERROR:
Trade Order Error: Parent price (1.000000) is more than 25% different than original Attached order price (-9.000000). Attached Order not modified. Internal order ID: 56663 | 2015-10-25 20:37:29 *
Trade Order Error: Parent price (1.000000) is more than 25% different than original Attached order price (9.000000). Attached Order not modified. Internal order ID: 56664 | 2015-10-25 20:37:29 *
Order goes through at -1031t
Market buy:
Trade Order Error: Parent price (1.000000) is more than 25% different than original Attached order price (11.000000). Attached Order not modified. Internal order ID: 56678 | 2015-10-25 20:45:38 *
Trade Order Error: Parent price (1.000000) is more than 25% different than original Attached order price (-7.000000). Attached Order not modified. Internal order ID: 56679 | 2015-10-25 20:45:38 *
Symbol  Trade Type  Entry DateTime  Exit DateTime  Avg Entry Price  Avg Exit Price  Entry Quantity  Profit/Loss (t)  Cum P/L (T)  Max Open Loss (t)  Entry Efficiency  Exit Efficiency  Total Efficiency  Drawdown (t)  Runup (t)  Max Open Profit (t)  Max Open Quantity  Exit Quantity  Commission (t)
[Sim]M6E-201512-CME  Long  2015-10-25 20:45:38  2015-10-25 20:45:51  1.0000  1.1030  1  1287.50, 1030  1287.50, 1030  0.00, 0  100.00%  99.71%  99.71%  0.00, 0  1291.25, 1033  1291.25, 1033  1  1  0.00, 0
Same issue with 6A/M6A and 6B/M6B
Date Time Of Last Edit: 2015-10-26 02:21:10
[2015-10-27 08:11:24]
It's okay, I fixed it.
It works perfectly now!
Mike.
Date Time Of Last Edit: 2015-10-27 08:28:31
[2015-10-27 09:14:02]
OK this is good. We did write up an answer for this but actually have not yet posted it.
It has to do with the real-time price multiplier being different.
[2015-10-27 09:18:59]
We have updated the documentation here about this:
http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TradeAndCurrentQuoteSymbol
[2015-10-27 10:37:39]
Thanks for the reply, yes that's what I did, good info tho.
Single buy/sell market orders work great but pending orders don't work, ie ATM's, SL, TP.
Is that correct behavior?
[2015-11-15 06:49:13]
You should not trust entering any order when using a Trade and Current Quote Symbol which has a different decimal point position unless you fully understand how it should work and the prices are set as you would expect.
Date Time Of Last Edit: 2015-11-15 06:50:00
