Date/Time: Sun, 04 Oct 2026 18:51:07 +0000
How can I enable the feature "Daily Net Loss Management" It is disabled
View Count: 1383
| [2015-10-25 23:33:38] |
| User402474 - Posts: 5 |
Dear Sirs , How can enable the feature "Daily Net Loss Management" ? Please see the attachement or where can I enable data-Feed ? (My Sierra chart is using TT) Thanks |
| [2015-10-26 00:41:34] |
You just need to press the OK button now that you have enabled Flatten Positions When Loss Rules Met. The feature will then be enabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-10-26 05:21:29] |
| Futures Operator - Posts: 239 |
This feature has been long requested, and is so great, thank you for adding it! PLEASE seriously consider enabling it to work for Simulated Trading/testing as well! |
