Date/Time: Sun, 08 Sep 2024 00:36:33 +0000
Volume by Price - Valleys fixed horozontal line levels
View Count: 774
[2015-10-25 21:47:19] |
User866531 - Posts: 14 |
Hi, Is there a way to fix the horizontal lines for the VbP Valley levels for the entire session. I'm trying to get the long term (120 days or some other user specified amount) valley levels to stay at the same price level they are at on the open. What is happening though is that these levels update constantly over the course of the day as more volume is added and sometimes shift when price comes back into them during the day. Is there a way that these levels can be fixed and then update any added volume just before the next cash session starts and then these levels are fixed again until the following day? So it is not adding developing volume but still updates the prior days volume automatically each start of cash session. |
[2015-10-25 22:47:01] |
Which are asking for is illogical based upon the design of the study. We would never add this capability. Instead what you need to do is set the time period of the Volume Profile to not include the current day. So you would want to use the Volume Graph Period Type of From Start Date Time to End Date Time: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#InputVolumeGraphPeriodType Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-26 04:42:54
