Date/Time: Mon, 14 Sep 2026 05:02:05 +0000
sc.RoundToTickSize function
View Count: 2635
[2015-10-24 20:50:32]
Johnny - Posts: 99
I have created subgraphs in my study that use this function in order to round numbers to the instrument ticksize value. When the value format equals the ticksize everything is fine, however when I increase the value format the numbers don't remain rounded to the ticksize value. So, for example with a value format of 0.0000001, 45.24 becomes 45.2399979. From my understanding when I increase the value format beyond ticksize the numbers must be displayed with more decimal points but remain rounded nonetheless. In this case I was expecting the number displayed to be 45.2400000. Does that mean that the function doesn't work properly?
[2015-10-25 00:08:40]
This is normal due to floating-point error:
http://www.sierrachart.com/index.php?page=doc/doc_StudiesSystemsAlerts.php#ImprecisionOfFloatingPointNumbers
[2015-11-02 16:46:48]
Johnny - Posts: 99
I'm trying to round floating-point numbers to only two decimal places and discard all the remaining in order to use them in internal study calculations. I've used the round function in the following way: round(Number * 100) / 100. But the division by 100 makes all the other decimal places appear again. Is there a way to achieve this?
[2015-11-02 17:59:26]
You need to use this function:
sc.RoundToTickSize(float Value, float TickSize)
Specify the increment with TickSize. For example .01.
This does does not solve a small degree of floating-point error. This will always persist.
[2015-11-02 19:01:30]
Johnny - Posts: 99
I'm aware of the sc.RoundToTickSize function but it's not enough. I'm comparing the VWAP values with the POC and OHLC values and I want to completely eliminate the floating-point error for ultimate precision. So, there's no solution for this?
[2015-11-02 19:14:12]
In this case you need to use this function:
ACSIL Interface Members - Functions: sc.FormattedEvaluate()
