Date/Time: Sat, 23 Nov 2024 04:41:19 +0000
Locked Scaling
View Count: 1659
[2013-06-18 18:22:24] |
infpz - Posts: 826 |
I created this difference chart. However I cannot adjust the scale, so if the value goes off the screen, I cannot adjust to see the current level. Any idea on how I can fix this?
difference.png / V - Attached On 2013-06-18 18:21:06 UTC - Size: 102.58 KB - 538 views |
[2013-06-19 02:28:13] |
Refer to this help topic: https://www.sierrachart.com/index.php?l=doc/helpdetails46.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
