Date/Time: Sun, 08 Sep 2024 00:40:32 +0000
Columns not adjustable in Tool Values Window
View Count: 711
[2015-10-24 05:58:38] |
tobi - Posts: 351 |
In prerelease 1314 the columns width in the Tool Values Window are no longer adjustable. I think we had this issue before, a little while ago. |
[2015-10-26 09:23:41] |
Never in the history of Sierra Chart, are the column widths adjustable in any of the Chart Values Windows. The widths are automatically set based upon the overall width of the window itself. We had a look at it now, and the text display is the same as always. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-26 09:24:09
[2015-10-26 09:47:52] |
tobi - Posts: 351 |
I'm sorry about this. I've mixed something up here. My bad.
