Date/Time: Fri, 02 Oct 2026 13:21:24 +0000
cpu requirement - which matters most?
View Count: 1638
| [2015-10-23 16:44:16] |
| infpz - Posts: 826 |
1 Number of cores on CPU; 2 Speed of CPU;and/or 3 Amount of L-1, L-2, L-3 or L-4 cache on the CPU? |
| [2015-10-23 18:43:44] |
We do not know the answer to this question and there is a huge amount of variables involved. Anyone who claims to know the answer to this question in isolation, is not giving you an honest answer. In general the more of all of these is going to be an improvement. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-23 18:44:24
| [2015-10-24 01:30:07] |
As we said the more of all of these is going to help, at least indirectly because it provides more computing resources to Sierra Chart. You should also definitely get a SSD (Solid-state drive). If you look at this page, you can get an understanding of how Sierra Chart uses multiple computer CPU cores: https://www.sierrachart.com/index.php?page=doc/Features.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-24 01:30:40
