Date/Time: Sun, 08 Sep 2024 00:37:24 +0000
Spreadsheet / buy entry code keeps disappearing when browsing tabs
View Count: 661
[2015-10-23 16:09:36] |
BataviaTrader - Posts: 63 |
I Keep loosing my piece of code in cell K3. 1. after putting valid code in this cell, Save, then I browse back to the chart. 2. There I open Studies Window and browse through settings without changing anything 3. I go back to the Spreadsheet and code is gone. Video below shows in detail the case. as English is not my mother tongue. Please inform. thank you. screencast.com/t/S8Kw6VTbodDC |
[2015-10-23 17:39:33] |
Refer to the information here about the Formula Source Sheet Number input: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudyInputs.html#FormulaSourceSheetNumber Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
