Date/Time: Fri, 18 Sep 2026 16:01:49 +0000
Is there a way to identify these scenarios without coding a new indicator?
View Count: 1151
| [2015-10-23 13:58:35] |
| Cavalry3162 - Posts: 523 |
like the headline hints, i am looking for a way to identify the following scenarios: 1. NYSE-Tick mostly above zero = bullish context (green boxes in screenshot) 2. NYSE-Tick tethering around zero = more like flat (yellow boxes) 3. NYSE-Tick mostly below zero = bearish context (red boxes) any help is highly appreciated! thank you, Andreas |
| [2015-10-23 18:52:12] |
You definitely have to do some programming. Have a look at using the Spreadsheet System/Alert study: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
