Date/Time: Fri, 18 Oct 2024 04:02:44 +0000
request for strategie
View Count: 755
[2015-10-23 13:24:16] |
User638836 - Posts: 8 |
Hi, I want to use strategie in sim ,but i d'nt find strategie in indicator's box !where i can find it? thank for your help |
[2015-10-23 17:42:57] |
You need to create your own automated trading system if that is what you are looking for. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_AutoTradeManagment.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
