Date/Time: Sun, 08 Sep 2024 00:41:38 +0000
detached windows position
View Count: 821
[2015-10-23 11:46:20] |
User411334 - Posts: 38 |
Hello support! I have 2 monitors connected to a laptop via displaylink adapters. And for some reason they have a tendency to occasionally switch off/on. When this happens all detached charts are moved to the laptop display. I will upgrade this configuration in the future but at this time is there a way to quickly save/restore all detached windows positions. So when this off/on cycle happens again i can simply restore all detached windows positions with a click instead of dragging them with a mouse on their old places? Thank you.
[2015-10-23 17:55:44] |
What you need to do is select File >> Save to save the Chartbook after you position all of the windows as you require. When this condition happens, select File >> Close Chartbook. Press No not to save that. Then open the Chartbook. For more information, refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-23 17:56:26
