Date/Time: Sun, 08 Sep 2024 00:44:01 +0000
IQ feed with volume by price not working correctly
View Count: 839
[2015-10-22 21:52:07] |
User83842 - Posts: 5 |
Hi, I just started with IQ feed and i only have big numbers, volume by price not working correctly because of that. Thanks, Silver |
[2015-10-22 23:05:48] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Describe precisely the problem that you see with the Volume by Price study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-22 23:06:04
[2015-10-23 06:06:50] |
Ok here is the image with the volume by price indicator for the day: http://www.sierrachart.com/image.php?l=1445580085968.png And here is the volume by price indicator thats 1 minute showing the volume profile in every sindle candle: http://www.sierrachart.com/image.php?l=1445580204849.png And here is the picture when i put these indicators on the IQ feed chart: the VBP 1 day: http://www.sierrachart.com/image.php?l=1445580313769.png and the 1 minute VBP: http://www.sierrachart.com/image.php?l=1445580357298.png |
[2015-10-23 08:37:59] |
The USDJPY chart VBP indicators are working with IQ feed, but UJ have different pricing, there must be something off with the pricing i guess.
[2015-10-23 09:30:39] |
Update the Symbol Settings following these instructions here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps After that apply them to the chart following these instructions: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps We have added the settings for the two symbols you have mentioned here. The problem is with the Tick Size. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-23 10:17:53] |
Ok now EURUSD is working but other pairs are not working. Can you add the settings for the all fx pairs please? Date Time Of Last Edit: 2015-10-23 10:23:08
[2015-10-24 01:01:45] |
Yes we can. But just give us a couple of days for this.
