Date/Time: Wed, 12 Mar 2025 17:12:47 +0000
Display Entry/Exit Connection lines + Display Fill Text
View Count: 2618
[2015-10-22 21:36:18] |
VaclavS - Posts: 21 |
Hello, I have installed Sierra chart on the my new PC and I am not able to display above mentioned informations in the chart in despite I have copied all settings of the Sierra chart from my old computer. I have copied also folder data and trades which were done on old PC are visible in the chart but the new trades are not displayed in the chart at all. It is SIM account and I do not see any trades in the Trade Activity Log. Can you advise to me what to check? |
[2015-10-22 23:11:51] |
What you are referring to is the display of Order Fills on the chart which is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#DisplayingOrderFills You should not have any trouble with new order fills displaying so long as the settings are correct. Refer to the documentation linked to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-22 23:12:05
[2015-10-23 16:41:22] |
Hello, unfortunatelly everythings is set as described bud connection lines and text is not displayed. Any idea how to fix it? |
[2015-10-23 16:51:49] |
May be: I see on the chart account (Sim) and in trade window chart I see account Sim1. Could it be the reason? How to get the same name of an account?
[2015-10-23 18:24:57] |
Trade activity log is also empty
[2015-10-23 18:35:32] |
So you are performing simulated trading and you do not see the order fills on that same chart you are trading from? And on the Trade Activity Log? If you do not see the order fills on the Trade Activity Log, then tell us the control settings at the top of the Trade Activity Log that you have. You definitely will see the order activity in the Trade Activity Log. If you are not, then you do not have one of the settings at the top set correctly. That is very obvious. Does this happen during a replay or real-time updating of a chart? Make sure your computer's clock is set accurately. Refer to help topic 38: Http://www.sierrachart.com/index.php?page=doc/helpdetails38.html May be: I see on the chart account (Sim) and in trade window chart I see account Sim1. Could it be the reason? Also update Sierra Chart to the latest release following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-23 18:41:02
[2015-10-23 19:03:23] |
yes, I do not see fills on the same chart I am trading from.
Date Time Of Last Edit: 2015-10-23 19:03:42
[2015-10-23 19:05:32] |
it happens during real time trading
[2015-10-23 19:10:48] |
At the top of the Trade Activity Log you need to select "Simulated". Currently you have "Non-simulated" selected. You also need to choose the symbol from the list of Symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-18 15:22:41] |
User353062 - Posts: 32 |
How to enable Entry/Exit Connection lines? It won't show on my chart.
[2022-05-18 16:23:46] |
John - SC Support - Posts: 38612 |
For the connecting lines the setting you want is Trade >> Chart Trade Settings >> Order Fills >> Display Entry/Exit Connecting Lines. Refer to the information here: Global Trade Settings Windows: Display Entry/Exit Connecting Lines (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
