Date/Time: Sat, 23 Nov 2024 04:42:24 +0000
Continuous Question
View Count: 1658
[2013-06-18 16:01:34] |
infpz - Posts: 826 |
Hi, any thoughts on this? I normally use my infinity charts with continuous contract data to get my daily pivots to match up with Rob Hoffman's daily pivots. For some reason ever since I rolled over my contracts or updated the chart software version I have not been able to select continuous futures contract on the chart settings advanced settings tab. Each time I try the check is cleared when I apply the change. |
[2013-06-18 16:21:35] |
The only time we know this could be the case is when the chart is in the process of building the Continuous Futures Contract. Is [C] displayed on the title bar of the chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-18 16:22:00
[2013-06-18 16:47:16] |
Not any more, before the roll over / software update the [C] was displayed on the title bar of the chart, following the roll over / software update the [C] has disappeared and I can no longer select the check mark for continuous futures contract on the chart settings advanced settings tab
[2013-06-19 02:49:27] |
OK, for something like this, we really just have to check this issue on the users computer and see what is going on. otherwise, we don't know what to say.
