Date/Time: Mon, 23 Dec 2024 20:08:22 +0000
FXCM FEED DOWN?
View Count: 712
[2015-10-22 17:01:01] |
ripsdips - Posts: 143 |
FXCM FEED DOWN?
[2015-10-22 17:42:28] |
We do see an interruption with the GER30 less than an hour ago but the data feed has continued. This was a problem on the FXCM side.
