Date/Time: Mon, 23 Dec 2024 20:10:51 +0000
entry time difference
View Count: 725
[2015-10-22 16:21:03] |
User72703 - Posts: 17 |
how come the entry time on the order / position window is different than my charts and computer? how to make it the same ? thx you!
[2015-10-22 18:11:53] |
The Entry Time field in the Trade >> Trade Orders and Positions >> Orders tab, is set to the Sierra Chart Time Zone: http://www.sierrachart.com/index.php?page=doc/doc_TimeZone.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
