Date/Time: Mon, 23 Dec 2024 23:49:04 +0000
Advice re: Approved 3rd Part Programmers for TPO Study "variation"
View Count: 1372
[2015-10-22 01:18:20] |
User68474 - Posts: 201 |
My goal is to find out if it's possible for me to create a custom "variation" for a traditional TPO Market Profile chart. Without going into detail at this point, I would like to expand the options for the setting for "TPO Letter/Block Time Period in Minutes". I contacted two of the recommended 3rd party programmers. My first inquiry resulted in: "...Thanks for considering me, but I only program Sierra Chart spreadsheet studies. This sounds like a project for a c++/ACSIL programmer. I can recommend..." and referred me to another on your list, whom I assumed was c++/ACSIL proficient, who replied: "...thanks for sending in the email. I am not sure I understood exactly what you need. Unfortunately, the TPO study you see in SC's is a built in SC study. I don't have access to the study code and thus cannot make any changes to it." Is this a dead end and thus impossible to take to the next step? Do you have any other recommendations? Is the code/language(please excuse my obvious lack of technical expertise and vocabulary) such that no 3rd Party approved programmer can work on such a variation for me? Thank you. |
[2015-10-22 04:03:25] |
This is not possible. No one outside of Sierra Chart would have access to the code for the TPO Profile Chart study.
[2015-10-22 04:38:13] |
Would it be possible for me to procure your services for programming?
[2015-10-23 10:14:59] |
We can have a look at this possibly in February or March 2016 when we expect to be working on the TPO Profile Chart study.
