Date/Time: Mon, 23 Dec 2024 20:00:50 +0000
Confirm Exit
View Count: 660
[2015-10-21 21:24:25] |
User150371 - Posts: 70 |
Hello, is there a way to set up a Confirmation when exiting the SC platform ? i.e to prevent closing the program by mistake, as I sometimes do. |
[2015-10-21 21:32:06] |
Yes, by default this exists. Just make sure that Global Settings >> General Settings >> Display Save All Option on Exit is enabled.
