Date/Time: Mon, 23 Dec 2024 20:26:10 +0000
Question about a plugin
View Count: 942
[2015-10-21 20:39:57] |
CMG - Posts: 179 |
Hello, On a program that I am debugging I found the following notes from a post from 2012, can you tell me what is this plugin about? https://www.sierrachart.com/supportboard/archive/index.php/t-38797.html Thanks as always #girlswhocode Patricia |
[2015-10-21 21:00:48] |
That "plug-in" is from a user. Not from us. So obviously we cannot tell you anything about it.
