Date/Time: Tue, 29 Sep 2026 16:37:48 +0000
Display calculated values of the spreadsheet on a chart
View Count: 1098
| [2015-10-21 17:49:11] |
| jochenfrenzel - Posts: 8 |
I am using the old speedsheet system and would like to display a calculated column of the spreedsheet in a Chart Region of my chart. Is that possible? The background is that it is much easier to make the calculations (add, multiply) in the spreadsheet than with many Add/Multiply-Studies. Date Time Of Last Edit: 2015-10-21 17:50:00
| [2015-10-21 18:23:48] |
Yes. You just need to use the standard Spreadsheet Study functionality: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
