Date/Time: Mon, 23 Dec 2024 20:20:44 +0000
flat in lmax account but not in sierra: how to synchronise.
View Count: 799
[2015-10-21 14:55:39]
sierra28 - Posts: 120
thanks
[2015-10-21 15:59:13]
You are referring to the Trade Stats for Charts tab.
Refer to the documentation for this here:
https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#ChartTradeStatsTab
This is going to be a common problem but should longer-term be solved once we use the XML connection to LMAX instead instead of their FIX connection which does not support reporting of Trade Positions.
Date Time Of Last Edit: 2015-10-21 17:25:18
[2015-10-21 16:21:42]
this is not for trade statistic but i have positions in the dom of sierra and i'm flat in lmax account.So i 'd like to be flat as well in the dom of sierra.
[2015-10-21 17:13:51]
so any solution to synchronise sierra dom position with real account position ?
[2015-10-21 17:16:23]
The position is calculated using the same order fills as the Trade Statistics.
You need to follow through the instructions given to clear the order fills.
We have given you the wrong link previously. This is what we meant to give you:
How this works is explained here:
LMAX Trading Service: How Current Trade Positions Are Determined
Date Time Of Last Edit: 2015-10-21 17:17:32
[2015-10-21 17:28:12]
No, because LMAX does not want to add this capability to FIX for unknown reasons.
[2015-10-21 17:59:45]
sorry but it doesn't works and i note that in the menu of dom i can't unchek "use order fill calculation position"
[2015-10-21 18:25:58]
i have delete 2 buy positions and i 'm flat.
thanks
Date Time Of Last Edit: 2015-10-21 18:30:31
