Date/Time: Mon, 23 Dec 2024 19:47:46 +0000
numbers bars gap
View Count: 1509
[2015-10-21 06:52:51] |
User844406 - Posts: 18 |
Hello, I have a question. Why is there space ahead of the actual bar in the NB chart? I have the same settings for NQ and it works perfectly. Please see the screen image. Thank you, Daniel http://www.sierrachart.com/image.php?l=1445410098492.png |
[2015-10-21 16:40:10] |
What space are you referring to?
[2015-10-21 16:48:26] |
The space on the right chart - Numbers Bars. Last bar on the left chart isn´t on the same position as the one on the left chart.
[2015-10-21 16:51:28] |
Screen is not complet - there is no left chart. But actual bar is on the same position as the arrow shows. On the right side of the arrow is space - it means there is a space ahead of the actual bar.
[2015-10-21 18:14:40] |
Refer to the documentation here about the right side fill space: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ScrollingTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-22 07:31:00] |
My question wasn´t clear. So once again. There is one bar ahead of the actual bar on the right chart (Numbers bars) with confusing info in the chart below. How can be there one bar extra on the right chart? http://www.sierrachart.com/image.php?l=1445498352251.png I am using the same settings on NQ and there is everything ok - left and right charts are matching. http://www.sierrachart.com/image.php?l=1445498626285.png |
[2015-10-22 08:53:38] |
It appears as though that extra column on the right side is the "Pullback Column". This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#PullbackColumn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
