Date/Time: Thu, 10 Sep 2026 09:01:33 +0000
Problem s with CQG
View Count: 1608
[2015-10-20 08:34:44]
Forward - Posts: 68
Hello i unchecked the Allow Support for Sierra Chart Data Feeds on myothers two PC and i can receive your Sierra Chart Data .
So now i Have 1 PC with iqFeed Data , 1 PC with CQG Data , and last PC with your Sierra Chart Data .
But now i have an issue , the second PC with CQG doen't receive any data from CQG .
This after the unchecked data.
I close Sierra and reopen the program but nothing Real Time Data .
How to fix this issue ?
[2015-10-20 10:03:11]
Is your CQG account authorized for market data?
You are able to use the Sierra Chart Exchange Data Feed when using CQG. So what is the purpose of running a second copy of Sierra Chart to use the Sierra Chart Exchange Data Feed?
[2015-10-20 11:51:59]
We want to help you with this, and the best way is for you to use the Sierra Chart Exchange Data Feed while connected to CQG.
If there is a particular symbol you do not see listed in File >> Find Symbol that you need, let us know.
We want to make this work for you.
[2015-10-20 17:23:35]
Forward - Posts: 68
I am using Sierra on 3 different PC for my research so
I can use the Sierra Exchange JUST on one PC becouse i pay for your data just for one PC .
If i don't uncheck " Allow support for Sierra Chart Data feed " on the others two PC , then i can't receive
the real time data from you .
You write to me :
This is the reason for the problem:
SC Exchange Data | Logon error from server : Limited to one connection per username for the requested data source. | 2015-10-19 14:53:26
More information about this is here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Connections
You can only use the Sierra Chart Exchange Data Feed from one copy of Sierra Chart at a time, unless you pay for additional connections. We see you are also using CQG. Are you using the Sierra Chart Exchange Data Feed with CQG as well?
I uncheked " Allow Support for Sierra Chart Data Feeds" on the CQG PC and iqFEED PC and now i can see the Real Time data on the 3° PC but no on the CQG PC
[2015-10-20 18:04:57]
You need to activate a second data connection to use with CQG. This can be done here:
https://www.sierrachart.com/usercp.php?page=MarketDataFeedFeatures
[2015-10-21 07:32:06]
Forward - Posts: 68
But i should like to take the CQG Data , not to have a second Sierra Chart Real time data connection
with your Data. This is becouse i pay already my broker for this .
[2015-10-21 15:55:08]
OK if you are not receiving data from CQG, then follow the instructions here in this section:
CQG Trading Platform Service: Market Data Authorizations for Symbols/Exchanges
If you still have a problem receiving data from CQG, then at that time post a copy of the Message Log so we can determine why.
Here are the instructions:
