Date/Time: Mon, 23 Dec 2024 20:15:39 +0000
Volume profile - updating in realtime?
View Count: 858
[2015-10-20 08:10:59]
User60518 - Posts: 106
Is it possible when using the DVP tool to have the profile continually build in realtime? As in not have an ending? I know the profile will build inside the rectangle I draw, but if after time the bars on the chart build past that point the volume profile no longer updates.
(a nice to have really - so I don't need to check if the rectangle is over future time on my chart)
Cheerrs
[2015-10-20 18:02:51]
This can be done and we will write instructions for how to do this.
However, for now manually add the Volume by Price study to the chart and use From Start Date-Time to End for the Volume Graph Period Type:
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#InputVolumeGraphPeriodType
[2015-10-21 04:19:10]
Here is the documentation for what you want:
http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ManuallyDrawnVolumeProfilesExtendToLastBar
However, we detected a problem as we were working on the steps. This will be fixed in 1314. So you will need to wait until then. Should be out in a couple more days.
