Date/Time: Mon, 23 Dec 2024 20:24:54 +0000
[User Discussion] - VOLUME FILTER T/S
View Count: 910
[2015-10-20 07:29:01] |
User899661 - Posts: 1 |
hOW CAN I FILTER THE VOLUME COLUME IN TIME AND SALES SO VOLUME READS > 15 THUS ELIMINATING THE 1 LOT RECORDS AND ALSO THOSE BELOW THE 15 TRESHOLD ?
[2015-10-20 08:12:49] |
User60518 - Posts: 106 |
select settings and choose the number of trades you want to filter by under the 'Filtering' section.
[2015-10-21 03:14:44] |
There are Volume filter settings in the Time and Sales Settings: http://www.sierrachart.com/index.php?page=doc/doc_TimeandSalesWindow.html#Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-21 03:15:02
