Date/Time: Mon, 23 Dec 2024 20:24:16 +0000
Video Tutorial
View Count: 2230
[2015-10-19 12:40:47] |
User19479 - Posts: 25 |
Do you have any video tutorials ? it's really difficult to use..
[2015-10-19 12:45:59] |
infpz - Posts: 826 |
Hello User19479 , I host this every Monday on Sierra Chart: http://www.infinityfutures.com/charting-webinar.aspx?ref=pzie 30 Day Free trial of InfinityAT + Sierra with live data: http://www.infinityfutures.com/practiceaccount.aspx?ref=pzie Videos: http://www.infinityfutures.com/videos.aspx?ref=pzie Thanks, Patrick Zielbauer |
[2015-10-19 17:49:42] |
What specifically do you need help with in Sierra Chart? There are some videos and they can be found here: Videos Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
