Date/Time: Mon, 23 Dec 2024 19:52:26 +0000
SC Data Feed Problem
View Count: 764
[2015-10-19 09:42:37] |
Futurestrader77 - Posts: 126 |
The SC Data Feed seems to have a problem. Sometimes the limit orders in the DOM are not reported correctly (gaps). Please see the attached pictures (Bund Future). Thank you!
DOM II.PNG / V - Attached On 2015-10-19 09:41:00 UTC - Size: 50.32 KB - 294 views |
[2015-10-19 10:05:38] |
We are not observing any gaps in the market depth for the FGBL with the Sierra Chart Exchange Data Feed, at the moment. Do you still notice a problem? If so, reconnect to the data feed following the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_FileMenu.html#ProcedureToReconnect Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
