Date/Time: Mon, 23 Dec 2024 20:18:53 +0000
lmax "account balance external service" study doesn't works.
View Count: 735
[2015-10-19 07:44:34] |
sierra28 - Posts: 120 |
whereas trading profit/loss text works.
[2015-10-19 08:03:30] |
Yes, this is true because the LMAX FIX server does not support this. This may be supported when Sierra Chart supports a different connection to LMAX for trading which we are currently looking into.
[2015-10-19 09:06:28] |
undestand, but why trading profit/loss works ?
[2015-10-19 09:14:34] |
That calculation is dependent on the Order Fills which Sierra Chart maintains as it receives order fills in real-time from the server.
