Date/Time: Mon, 23 Dec 2024 19:21:03 +0000
can't connect
View Count: 724
[2015-10-18 13:57:20]
User98466 - Posts: 7
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-10-18 09:55:51
Socket (16) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-10-18 09:55:52
Socket (16) | Shutdown and closed. | 2015-10-18 09:55:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-10-18 09:55:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-10-18 09:55:52
TransAct Trading | Disconnected from the server. | 2015-10-18 09:55:52
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-10-18 09:55:52
File >> Disconnect selected. | 2015-10-18 09:55:53
TransAct Trading | Disconnected from the server. | 2015-10-18 09:55:53
[2015-10-18 18:08:29]
I am able to connect now.
[2015-10-18 19:57:29]
For future reference for this kind of a problem, refer to this section here:
https://www.sierrachart.com/index.php?page=doc/TransAct.php#BridgeConnectionError
