Date/Time: Mon, 23 Dec 2024 19:40:45 +0000
Vertical Line at the begining of the session
View Count: 1267
[2015-10-18 01:35:10] |
User167108 - Posts: 49 |
I am using 24 hours chart and would like to get a vertical line at the start and end of day trading session . Please advise how can i achieve it
[2015-10-19 07:14:19] |
User13668 - Posts: 294 |
I assume you mean vertical lines at the start and finish of the S&P Emini regular trading hours being 9.30am and 4.00pm USA ET? Try using multiple instances of the Time Line study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s181 |
[2015-10-19 09:23:24] |
You can do this with the Vertical Grid which is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#Vgrid Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
