Date/Time: Tue, 22 Sep 2026 19:05:30 +0000
info about Interactive Brokers and SC real time data feed
View Count: 1088
| [2015-10-17 14:26:12] |
| more - Posts: 154 |
Hello, i'm interested to use Interactive Brokers and SC real time data feed. But i read the page of IB in this site, and i would like to know if it happens that there are technical issues when using Interactive Brokers, because i'm not technically competent with computers and software, and i don't understand the source of technical problems. And what are the issues the could happen? Thanks |
| [2015-10-17 23:11:54] |
If you are using the Sierra Chart Exchange Data Feed with Interactive Brokers, you will not have market data problems. So you do not need to be concerned about those notes on the Interactive Brokers page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
