Date/Time: Mon, 23 Dec 2024 19:20:02 +0000
[User Discussion] - Drawing persistent different text values that will be attached to bars in the chart
View Count: 765
[2015-10-17 07:30:03]
KhaosTrader - Posts: 128
I need to be able to write text values on the swing highs and lows of the chart, which need to be attached to the swing level, and persist in the chart. Can you point me to some examples where I can learn how to do this.
Thanks.
[2015-10-17 07:50:00]
I am experimenting looking at
http://www.sierrachart.com/index.php?page=doc/doc_ACSILDrawingTools.html#UsingTools
i dont have a clear example, but iterating different ideas is giving me results.. So I can work on this on my own, when I need help I will ask, however if you have a great example, please let me know, I will also study it.
Thank you.
[2015-10-18 04:44:29]
You can find examples of the sc.UseTool function placing text on the chart in the /ACS_Source folder.
Simply search for DRAWING_TEXT among those files and you will find an abundance of examples.
