Date/Time: Mon, 23 Dec 2024 19:21:50 +0000
Cross Hair
View Count: 862
[2015-10-16 17:14:51]
User700956 - Posts: 18
I changed the background color from white to blue. With that change I had to change the cross hair to black. When I move the cross hair up and down the price scale on the side of the chart it shows white. How do I change that to black. Thank you RC Johnsen
[2015-10-16 17:36:41]
When the Chart Values tool is active, post an image of the chart showing this so we can better understand what you are referring to.
The Chart Values crosshair is combined with the background color using a mathematical operation so it may not appear exactly as the color that you select. You will need to try different colors until you get the appearance that you require. The reason for this combining of the color allows it to be removed by redrawing it using a different mathematical operation. This makes the Chart Values tool efficient when being used.
Date Time Of Last Edit: 2015-10-16 17:38:19
