Date/Time: Fri, 20 Nov 2026 14:04:19 +0000
micro FX data issue
View Count: 1167
[2015-10-16 11:56:54]
User742717 Mike - Posts: 86
Hi SC,
Having data issue on TT/Amp, M6C, M6J and M6S, everything else is fine.
All look the same, ie: M6J
http://www.sierrachart.com/image.php?l=1444996551279.png
Cheers
Mike.
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\M6J-201512-CME.scid | 2015-10-16 06:51:41
AMP/TTNet | Starting real-time market data updates for: M6J-201512-CME. ID: 1 | 2015-10-16 06:51:41
Requesting market data for M6J-201512-CME. Depth levels: 1 | 2015-10-16 06:51:41
Intraday data recording state for symbol M6J-201512-CME is set to download 'Pending'. | 2015-10-16 06:51:41
HD Request # 2 | Downloading Intraday chart data for M6J-201512-CME to the file M6J-201512-CME.scid. Service: ttamp | 2015-10-16 06:51:41
Compressing file: C:\SierraChart\Data\M6J-201512-CME.scid. This may take a while. | 2015-10-16 06:51:41
HD Request # 2 | Download start Date-Time: 2010-04-25 06:51:41.000 | 2015-10-16 06:51:41
HD Request # 2 | Using server: ttamp.sierracharts.com port 10149 | 2015-10-16 06:51:41
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-10-16 06:51:41
Socket (6) | Connected. | 2015-10-16 06:51:42
HD Request # 2 | Sending historical data logon request message. | 2015-10-16 06:51:42
HD Request # 2 | Requesting Intraday data. Start Date-Time: 2010-04-25 06:51:41. Record interval: 0. Symbol: M6J-201512-CME | 2015-10-16 06:51:43
HD Request # 2 | Decompressing data. | 2015-10-16 06:51:43
HD Request # 2 | Receiving Intraday data for M6J-201512-CME starting at 2015-09-17 22:30:25 | 2015-10-16 06:51:43
HD Request # 2 | Timestamp of first Intraday data file record written: 2015-09-17 22:30:25 | 2015-10-16 06:51:43
Socket (6) | Shutdown and closed. | 2015-10-16 06:51:43
The network socket for historical data has been closed. | 2015-10-16 06:51:43
HD Request # 2 | Received 17 records from 2015-09-17 22:30:25 to 2015-09-18 02:59:57 (4.5 hours) and wrote 17 records for M6J-201512-CME | 2015-10-16 06:51:43
HD Request # 2 | Intraday download COMPLETE for M6J-201512-CME. Completion time: 2s. Unique request ID: 1 | 2015-10-16 06:51:43
Removed historical data download ID 1 | 2015-10-16 06:51:43
Real-time Intraday chart data file updates started for M6J-201512-CME | 2015-10-16 06:51:43
M6C
M6S
Intraday data recording state for symbol M6S-201512-CME is set to download 'Pending'. | 2015-10-16 06:54:44
Reloading all charts with filename: M6S-201512-CME.scid | 2015-10-16 06:54:44
HD Request # 6 | Downloading Intraday chart data for M6S-201512-CME to the file M6S-201512-CME.scid. Service: ttamp | 2015-10-16 06:54:44
HD Request # 6 | Download start Date-Time: 2010-04-25 06:54:44.000 | 2015-10-16 06:54:44
HD Request # 6 | Using server: ttamp.sierracharts.com port 10149 | 2015-10-16 06:54:44
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-10-16 06:54:44
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\M6S-201512-CME.scid | 2015-10-16 06:54:44
Socket (11) | Connected. | 2015-10-16 06:54:44
HD Request # 6 | Sending historical data logon request message. | 2015-10-16 06:54:44
HD Request # 6 | Requesting Intraday data. Start Date-Time: 2010-04-25 06:54:44. Record interval: 0. Symbol: M6S-201512-CME | 2015-10-16 06:54:44
Socket (11) | Shutdown and closed. | 2015-10-16 06:54:45
The network socket for historical data has been closed. | 2015-10-16 06:54:45
HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M6S-201512-CME | 2015-10-16 06:54:45
HD Request # 6 | Intraday download COMPLETE for M6S-201512-CME. Completion time: 0s. Unique request ID: 5 | 2015-10-16 06:54:45
Removed historical data download ID 5 | 2015-10-16 06:54:45
Real-time Intraday chart data file updates started for M6S-201512-CME | 2015-10-16 06:54:45
[2015-10-16 18:37:36]
What is the "data issue"?
The chart you posted looks just fine to us.
Check with the exchange to see the trading activity on these markets.
[2015-10-16 18:49:02]
Just to be clear it is very unlikely there is any problem here.
If you have further questions about these markets please contact your broker and not us. It is your responsibility to understand what you are trading and to confirm what you are seeing is valid. This is not our responsibility. You need to understand the markets that you are trading.
