Date/Time: Mon, 23 Dec 2024 19:27:28 +0000
Help topic 15 - add reminder to copy sound files (.wav)
View Count: 1001
[2015-10-16 10:28:35] |
User13668 - Posts: 294 |
You should add a note to the below section of the documentation reminding a user to also copy any unique .wav sound files they have created for alerts. Transferring Sierra Chart Settings and Data From Existing Installation to New Installation |
[2015-10-16 18:03:55] |
The documentation has been updated.
