Date/Time: Sun, 08 Sep 2024 01:35:02 +0000
Correct Daily open
View Count: 713
[2015-10-16 02:41:39] |
User868662 - Posts: 9 |
Hello, How do i get the correct daily open number which is reflected in the daily chart into an intraday chart? Even though in the DAILY OHLC indicator i give the correct daily chart # for reference it still not picking up the correct open number. Please help. Thanks |
[2015-10-16 04:49:56] |
You must set the "Use this Intraday Chart" Input to No to actually reference the Daily chart. Based upon what you are saying the Historical Daily chart is not being referenced. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-16 04:50:09
