Date/Time: Sat, 26 Sep 2026 08:55:40 +0000
market orders and BHCS_BAR_HAS_CLOSED
View Count: 2168
[2015-10-15 17:35:36]
cmb999 - Posts: 211
In a bar-based back test, i am checking:
sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED
before creating and sending a market order.
however, the market order does not execute until the close of the bar (or open of next one, cant tell which yet).
how can i get the open of the current bar (or near it) to be the execution price for the market order as it would be in real-time ?
[2015-10-16 00:08:06]
ejtrader - Posts: 689
You can check my earlier post - it should help in this case as well.
ACSIL - How to run part of code only once per bar | Post: 57332
[2015-10-16 20:09:04]
It would make sense to send the order when a new bar is added to the chart if the conditions are met.
This code example will help:
SCSFExport scsf_DetectingNewBarsAdded(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    // Set the configuration and defaults
    sc.GraphName = "Detecting New Bars Added";
    sc.AutoLoop = 1;
    sc.FreeDLL = 0;
    return;
  // Do data processing
  int& PriorArraySize = sc.GetPersistentInt(1);
  //This is not a full recalculation of the study
  if (!sc.IsFullRecalculation)
    // If there are new bars added
    if (PriorArraySize < sc.ArraySize)
      // put processing here that is required for when new bars are added to the chart
  PriorArraySize = sc.ArraySize;
