Date/Time: Sun, 08 Sep 2024 01:54:36 +0000
Importing EOD Data Every day
View Count: 1073
[2015-10-15 14:01:45] |
RitikaGupta - Posts: 7 |
Hi, 1) Once i import EOD data for 3000 Symbols from One Single Text file, how will i append daily EOD data daily? 2) Will the incremental data append automatically along with historical imported data. Right? |
[2015-10-15 17:55:54] |
Sierra Chart does not support what you are looking for.
