Date/Time: Wed, 16 Sep 2026 03:39:36 +0000
How to do this with Volume Profile?
View Count: 1255
[2015-10-15 03:23:47]
RitikaGupta - Posts: 7
Team,
I have two types of volumes in my data. 1) Total Traded Volume 2) Delivery Volume.
I want to plot both of them on the Y Axis (Left Horizontal). Is it possible?
If yes then how?
[2015-10-15 03:42:37]
The Sierra Chart data files do support Bid Volume and Ask Volume. So if you set the Delivery Volume into Bid or Ask Volume you could display it that way. The Volume by Price study does support displaying Bid and Ask volume.
Refer to this page here:
Intraday Data File Format
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php
Date Time Of Last Edit: 2015-10-15 03:43:27
[2015-10-15 11:57:09]
1) So are you talking about :
Symbol, Date, Time, Open, High, Low, Close, Volume, Number of Trades, Bid Volume, Ask Volume (Header is required. Intraday data only.)
If so, at the end is says "Intraday data" only. but my data is EOD data. So what to put in TIME field?
2) All my data is in one sigle TXT file which has 3 years of EOD data for 3000 Symbols. so I will be able to import One single TXT file right? I read somewhere that there should be one TXT file with the file name of each Symbol. Is it true?
Date Time Of Last Edit: 2015-10-15 12:00:31
[2015-10-15 17:34:39]
This is not going to work. Also you are asking about nonstandard functionality.
Sierra Chart is not going to meet your requirements.
