Date/Time: Mon, 23 Dec 2024 17:30:05 +0000
Tick Size for CL.FUT_SPREAD
View Count: 1104
[2015-10-14 15:51:36]
User210422 - Posts: 19
Guys the default tick size for CL.FUT_SPREAD should be 0.01, not 0.0001.
[2015-10-14 16:52:30]
What version of Sierra Chart are you running?
It is set to .01.
Update the Symbol Settings as explained here:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps
After that apply them to the CL~.FUT_SPREAD chart by following these instructions:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps
Date Time Of Last Edit: 2015-10-14 16:52:44
[2015-10-14 16:53:53]
odd I just updated to 1309 this morning and it changed?
[2015-10-14 17:20:59]
It is still .01. Follow the instructions we gave and it will be set correctly.
