Date/Time: Mon, 25 Nov 2024 23:46:31 +0000
Chart Header Font
View Count: 1585
[2015-10-13 18:43:39] |
User795833 - Posts: 15 |
How can I change the chart header font, i tried Graphic Settings>Font, but it doesn't work. Can I also move the Bid/Ask data over to the far right so it is separate from the rest of the data line. Another question I had, whenver I open Sierra charts I need to manually open my workbooks. Is there a way for my workbooks to open automatically whenever i open up the Sierra Charts program. Thanks. |
[2015-10-14 07:47:49] |
The Chart Header uses the "Chart Text" font. Here is the documentation for setting fonts: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html#Fonts Here is the documentation for customizing the Chart Header: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeChartHeader Here is the documentation for automatically opening files: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#FilesToOpenOnStartup Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-29 18:11:39] |
User893396 - Posts: 39 |
Does that mean that it's impossible to make the chart header bigger without changing all the font sizes of the scales, the studies region data... If that's the case would you consider adding a feature so we can have for instance a big header with time, description, etc. without having huge scales numbers. Thank you |
[2021-04-09 04:28:16] |
Up
[2021-07-29 06:00:18] |
Can somebody answer please? I have this problem for months now...
[2021-07-29 14:50:10] |
John - SC Support - Posts: 36286 |
Yes, that is correct. We will add your request to our list of work items, but we can not say when (or even if) we will get to it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-22 16:36:54] |
User34124 - Posts: 276 |
Just checking if any update
