Date/Time: Thu, 10 Sep 2026 20:47:50 +0000
Slow Data
View Count: 1123
[2015-10-13 13:43:46]
User25244 - Posts: 123
My charts have a intermittent lag of up to 4sec
I am using SC data feed
[2015-10-13 17:22:12]
What is the symbol of the chart?
Also disable the market depth features:
https://www.sierrachart.com/index.php?page=doc/helpdetails4.html#h4.9
An issue like this most likely is from not having enough bandwidth on your side. Here is the all the information about this kind of problem:
Prices / Data Falling Behind
Date Time Of Last Edit: 2015-10-13 17:22:56
[2015-10-13 17:38:26]
es-201512
[2015-10-13 17:49:31]
And do you see a [M] after the symbol at the top of the chart?
[2015-10-13 17:51:40]
y
[2015-10-13 17:55:07]
OK this is good.
Disable the market depth features:
[2015-10-13 18:13:05]
When I open up Data/Trade Service Settings IB (trading) is listed Is this correct if I have SC data?
[2015-10-13 18:32:45]
Yes, this is correct and the data feed is coming from the Sierra Chart Exchange Data Feed. This is explained here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Integration
