Date/Time: Mon, 23 Dec 2024 15:54:11 +0000
Evening Session showing 24 hours
View Count: 670
[2015-10-13 05:54:05] |
John M - Posts: 171 |
Use Evening Session is checked, Start is 15:30:00, End is 08:30:00 Time Zone is Central All I want is the overnight period but it's drawing 24 hours, 15:30 to 15:30 Day session is fine. This should be simple, what am I missing ? thank you |
[2015-10-13 06:03:47] |
If you only want to see the evening session you need to uncheck Use Evening Session and set the Start Time to 15:30:00 and the End Time to 08:30:00.
