Date/Time: Mon, 21 Sep 2026 13:38:36 +0000
How to test for a color
View Count: 1036
| [2015-10-13 04:30:23] |
| User35326 - Posts: 57 |
SC or anyone who knows the code: How do I test for a color when I am writing an alert? For example, I have this so far: =and(id5.sg1 > 80, id5.sg1 = "0,240,120,255,0,0" ) where 0,240,120,255,0,0 is the color I am trying to test for. I just don't know the proper syntax in the language that sierra uses and I couldn't find an example. Thanks in advance. |
| [2015-10-13 21:34:54] |
This is not supported. You can only make comparisons to the actual numeric values in Study Subgraphs.
